Automatic Transmission Fluid (atf)
Posted 23 March 2012 - 05:59 PM
  • 71,466 posts
QUOTE (ShiftVQV6 @ Mar 23 2012, 03:10 PM) <{POST_SNAPBACK}>
pinjam to ask.... is it normal to change automatic gear cable ?? does this cable get spoil easily?
#32
rallychamp
Posted 24 March 2012 - 02:27 AM
rallychamp
    hands on habbit
  • 4,669 posts
those shifting cable be it manual or auto was the last thing to fail on transmission assembly....almost next to not failing at all...
even in worst case scenario one just need proper cable adjustment for proper gear engagement and getting it lubricated to avoid freezing
(NFS Underground)
#33
Posted 24 March 2012 - 11:34 AM
  • 71,466 posts
QUOTE (rallychamp @ Mar 24 2012, 02:27 AM) <{POST_SNAPBACK}>
Got one time, my manual gear cable pop out of their socket, so gear cannot shift. Just have to push them back into the sockets.... smile_tongue.gif
#34
rallychamp
Posted 24 March 2012 - 12:09 PM
rallychamp
    hands on habbit
  • 4,669 posts
QUOTE (vr2turbo @ Mar 24 2012, 11:34 AM) <{POST_SNAPBACK}>
thats the cotter pin failing only....hehehehe....
(NFS Underground)
#35
Posted 26 March 2012 - 10:27 AM
  • 71,466 posts
QUOTE (rallychamp @ Mar 24 2012, 12:09 PM) <{POST_SNAPBACK}>
Plug them back and use until now, quite a few years already...... smile_wink.gif
#36
ShiftVQV6
Posted 26 March 2012 - 11:27 AM
ShiftVQV6
  • 5,659 posts
smile_disapprove.gif really dont know how they drive, cost me rm615 to change the gear cable.
#37
Posted 26 March 2012 - 11:36 AM
  • 71,466 posts
QUOTE (ShiftVQV6 @ Mar 26 2012, 11:27 AM) <{POST_SNAPBACK}>
If cable type, they push and pull at different angle when gear is selected.
If you open up the bonnet, then get someone to select the gears, you can see the cable movement in the engine compartment, gear box area....
#38
ShiftVQV6
Posted 28 March 2012 - 09:07 AM
ShiftVQV6
  • 5,659 posts
if gear cable snap or spoiled, will it cause the engine to die off?
#39
Posted 28 March 2012 - 10:25 AM
  • 71,466 posts
QUOTE (ShiftVQV6 @ Mar 28 2012, 09:07 AM) <{POST_SNAPBACK}>
#40
ShiftVQV6
Posted 28 March 2012 - 05:03 PM
ShiftVQV6
  • 5,659 posts
ok
thanks.
