Posted 17 February 2012 - 03:18 PM
huh? are there??
what kinda accessories?
mind to share?
thank you thank you
Aiyah! you mentioned volt meter mah! Nowadays, all sorts of meters, gadgets etc......
sytians
Posted 17 February 2012 - 03:19 PM
sytians
any car accessories shop will have it...
who knows maybe his woofer requires 2,000 watts...
thanks bro...
cheers
rallychamp
Posted 18 February 2012 - 03:04 AM
in broad daylight might be enuf...
but if during raining+night where u turns on all light and wiper at same time+signal into junction (slow moving) might not enuff....
normally just requiring u to upgrade the alternator into bigger capacity type....90Ampere or 120Ampere would do fine compared to stock...
other than that not needed...
Posted 19 February 2012 - 01:24 AM
hahaa
just normal set-up.... 2 amps, 1 pair tweeter, 1 pair mid, 1 sub 12"
Aiyoh sure can lor.
Even if you're going to put in 4 X 2000watt amps, + 4 X 15" Sub + 6 X mid, I think also no problem, add capacitor lor. But please make sure you start your car before any boom boom action.
Ram me if you can!SplitFire
fkmfkm
Posted 19 February 2012 - 12:23 PM
Aiyoh sure can lor.
capacitor can suply current if alternator not enuf ?
4 X 2000 that is 8000 watt LOL... dunno how big this cable need to be...
Posted 21 February 2012 - 10:09 AM
Can use 2.5 full copper wire?
sytians
Posted 16 March 2012 - 10:38 AM
sytians
haha...
thank you all sifus for the advise....
thank you thank you..
ShiftVQV6
Posted 23 May 2012 - 01:52 PM
just wish to ask....
some car accessories shop will strip the car bare to the metal to lay the cable for amps and sub...... some car accessories shop just hide these cables under the carpet next to the seats.....
is there any different ??
fkmfkm
Posted 23 May 2012 - 11:52 PM
bare metal for the ground.
Posted 24 May 2012 - 11:05 AM
i dont think he meant grounding, just the laying of cables under the carpet
all depends on how much work is involved, usually if take out all seats and carpet means doing a full system or big upgrade involving multiple amps etc
if simple upgrade like adding one amp usually remove one seat is enough, carpet can be removed at area involved only, and cables can be hid by the side, under carpet also, no need to fully remove it.
