Saga Blm, Fl Rear Drum Brake
Posted 11 February 2012 - 10:25 PM
Posted 11 February 2012 - 11:10 PM
When you change the rear drums of a low end car like the Saga there are some other things you need to consider too. E.g. what about the handbrake that acts on rear drums? What about brake balance adjustments and calibrations? What about JPJ approvals? etc
While it is nice to have, the cost may be too high to perform such mods.
Flee
Posted 12 February 2012 - 11:28 AM
For handbrakes, well the whole conversion will have to include that.
Posted 12 February 2012 - 09:18 PM
i found epol site about saga rear brake conversion here
http://apulgarage.bl...r-saga-blm.html
Posted 13 February 2012 - 11:01 AM
Posted 15 February 2012 - 12:29 PM
As I have said before, you may not notice the improved braking that much as most of the braking is done at the front.
Flee
Posted 15 February 2012 - 01:21 PM
Rear disc looks better mah......
For improved braking mod the front, as mentioned by bro. flee.....
Posted 15 February 2012 - 10:04 PM
proton has issue on rear drum, piston occasionally or easily jammed. so for me changing to disc will eliminate this problem.
Posted 15 February 2012 - 10:47 PM
I see many ah beng's car spray red or stick on plastic cover to look like Brembo hahahaha
Posted 16 February 2012 - 12:18 AM
but other alternative is gsr ck/evo 4,5,6....perhaps can get a bit cheaper...
(NFS Underground)
