Reduce Wind, Motorbikes, Buses And External Noise.
adrwoon
Posted 10 February 2012 - 03:02 PM
adrwoon
  • 931 posts
QUOTE (vr2turbo @ Feb 10 2012, 01:46 PM) <{POST_SNAPBACK}>
Penny wise, pound foolish......My old , old ride should benefit very well with this, as the rubber are now super compressed.... smile_blackeye.gif
"Penny wise, pound foolish" - I haven't heard that in a while...
Your old, old ride would also benefit from a bl@wj@b from Desmond too...
I don't want to be a genius - I have enough problems just trying to be a man.
Albert Camus
simoniz
Posted 10 February 2012 - 03:18 PM
simoniz
  • 255 posts
QUOTE (adrwoon @ Feb 10 2012, 03:02 PM) <{POST_SNAPBACK}>
should take up the Silver and Gold package offer by Des if have not been done yet, then can really feel the difference. smile_clown.gif
if you do, please let me know when, if you can let me feel the before and after effect, that would be superb. smile_big.gif
Posted 11 February 2012 - 10:13 PM
  • 71,466 posts
Firstly, I need to sup up my suspension first, then only think about the above..... smile_big.gif
sandra99
Posted 25 April 2012 - 07:44 PM
sandra99
    5th Gear
  • 5 posts
Such a nice article I will definitely share this with my friends.Keep writing .
ryder
Posted 20 April 2014 - 07:42 PM
ryder
  • 406 posts
QUOTE (dchong @ Feb 1 2012, 06:56 PM) <{POST_SNAPBACK}>
The Fantastic 3M Door Seals are Back !!!
New stocks just arrived. Sorry for the long delay. Some bros waited 6 months for this smile_blush.gif
* Reduce Wind noise
* Reduce external Traffic noise Significantly esp. Buses, Kap-chais.
* Solid luxury door closing Sound and Feel.
* seals off odour and fumes from outside
* Genuine 3M adhesive for long term performance
There are 2 versions. We will advice which is suitable for your ride.
A) 3M Door Seals. similar to luxury cars.
Rm 280 for 4 doors
PLUS install with 3M adhesive Primer for long term enjoyment.
Installation time: 45 mins
OR
cool.gif Rubber Stents
Silicone inserts to stock door seals to improve sealing
from Rm 180 for 4 doors.
Installation time: 1 hr.
" Well, all I can say is it makes a world of difference."
Simoniz
forum.autoworld.com.my/index.php?showtop...00&#entry1794341
*there are similar products out there but you have to feel and compare the Quality here.
Cheers,
Desmond
KL AUTO
Will these products work for Ford Focus.
There is wind noise for Ford Focus starting from 100km/h. The wind noise gets louder at higher speeds. Can any of these products work for the Focus by making it quiet up to 150km/h? In other words, no wind noise up to 150km/h?
Actually how does this wind noise come up? Does the wind seep through the rubber seal between the door and windscreen?
Posted 21 April 2014 - 08:31 AM
  • 71,466 posts
QUOTE (ryder @ Apr 20 2014, 07:42 PM) <{POST_SNAPBACK}>
Better contact him directly as he is less in the forum nowadays....
KL Auto Accessories Sdn. Bhd.
No: 66, Jalan Dato Haji Eusoff, Kompleks Damai
Off Jalan Ipoh, 50400 Kuala Lumpur
Tel: 603-4042 9928 / 603-4044 9928
H/P No: 017-282 3073 (Desmond Chong)
http://www.autofoam.com.my/
http://www.facebook....193456474019263
jamespaul
Posted 15 May 2014 - 04:35 PM
jamespaul
  • 180 posts
I dont think these products will work for your focus. if you are rich, do try different methods by all these so called experts and proven resutls.
the most effective way is to run your vehicle through wind tunnel and detect where the source is. typically, its wind noise is design flaw (or compromise).
mr. autofoam will tell, you to foam here and there. i am almost certain that it will make little or no difference.
then he will recommend head package, bottom package and ketiak package.
it too will help little. but after 3 rounds, you realised that you've been taken for a ride.
if you enjoyed the ride, its fine. but if you didnt, you would be poorer and unsatisfied.
cbsteh
Posted 16 May 2014 - 07:16 PM
cbsteh
  • 1,531 posts
QUOTE (jamespaul @ May 15 2014, 04:35 PM) <{POST_SNAPBACK}>
Kakaka. Well said.
adrwoon
Posted 18 May 2014 - 11:28 AM
adrwoon
  • 931 posts
Almost a month old, but I'll chip in my 2 cents... Wind noise at speed is terribly hard to get rid of. Door visors, wing mirrors, gaps in wheel wells can all contribute. If it's a whistling sound in your cabin, then there's a gap somewhere. I had wind noise issues past 120km/h, and traced it to a very tiny gap between my roof panel and sunroof - so even slightly ill-fitting body panels can be a pain in the neck.
Albert Camus
jamespaul
Posted 20 May 2014 - 09:43 AM
jamespaul
  • 180 posts
QUOTE (adrwoon @ May 18 2014, 11:28 AM) <{POST_SNAPBACK}>
hence, a proper wind noise solution is to actually run it through a wind tunnel. wind tunnels can simulate head wind, and cross wind. pin point the source.
then call yourself a specialist, because you will 100% fix that issue.
Not, taking a needle and stabbing it, maybe just maybe, fix the issue.
for me, thats as good as saying, the proton is the best car because you havent driven any other car out there.
