eohl79
Posted 04 January 2012 - 02:16 PM
Good write up.....
You can check with Henry, I remember Osren have the acid base glass cleaner also.
For interior with tint, I am now using DG glass cleaner.......
Yup, they have the acid based cleaner but after consulting them they said better don't use it. Old car have plenty of pits, scratches, etc on glass surface. Acid based cleaner not suitable. That's why the topic is "Safe and effective watermark removal". Don't need to standby water to quickly wash off etc. Want a solution the easy way where even a noob can do it. Just that my method cost a bit more $$$. BTW the Osren acid watermark cleaner is in a big bottle and quite cheap also. I think cheaper than the Forma Hero, etc for the volume.
I might want to experiment on the other glass with RB+velvet or denim spot buff pad using a paste of the abrasive (mix ownself) or maybe P40...
Posted 04 January 2012 - 02:54 PM
Nowadays I will try Glass Polish, if not scratch X and still cannot then I will acid.
I have acid my VR window all round before, as those times don't have anything to remove it. I even tried rubbing compound and it does not come off. Car that time bought 2nd hand and left for years in Rain and shine.....
eohl79
Posted 04 January 2012 - 11:03 PM
Bro Henry mentioned not to use acid especially on wiper area. Acid can seep into the crevices of the scratch and cause more problems. Not really visible if never do any inspection with LED lights. That's why need to try to avoid acid on front and rear windscreen if have wiper. Take note, pics taken after watermark removal.
Figure 1: Rear wind screen with wiper scratch marks
Figure 2: Zoom in of scratches from wiper
Posted 04 January 2012 - 11:55 PM
i just did over the weekend on my old junk...rotary with ScratchX and ScratchX + Autosol on my old junk mirror and winscreen....the glass were really 'clean' after few passes @ around 600rpm (max 900rpm)...there was no beading after that...then i re-apply Rain-X and let it cure for about 20-30 mins before buff off...now the beading is back and look cun
Can't really tell before rotary my winscreen got fine swirl/scratches or not (coz its old edi, i dun bother to check with LED etc...as long it bead...got watermark also nevermind)...but after clean, i do see some fine swirl under reflection inspection...(well takpe as long its really clean + no watermark now....)...+ i am happy
eohl79
Posted 05 January 2012 - 09:36 AM
good for you. You use 4 ply wool + autosol + scratchX?
I did try Opti Compound II with PFW (no 4-ply wool in my arsenal yet) and RB on my rear windscreen before (tempered glass). Went all the way up to 1500 rpm and back down. No visible watermarks and looks clean (not under inspection lights). Later on did see water streaks coming back after rain but no watermark spot. So looks like mine etched deeper. AFter the sanding, did not see any streakmark etching anymore. Will see how it goes... not raining these few day, very hot.
Posted 05 January 2012 - 11:53 AM
i dun go so aggressive, only use foam pad ....
now everyday i touch the screen also feel so slicky
....(covering dust also)..i will wash the car maybe tomorrow night...sure will see water beading like mad
Posted 05 January 2012 - 07:01 PM
we both have the same scratches on windscreen..
Posted 05 January 2012 - 09:37 PM
I normally ROB with LC white, using glass polish. Not strong enough, then scratch X.
Finish with glass cleaners, then either Rain X other brand or DG Rain Repel.....
Posted 06 January 2012 - 12:01 AM
i got Gtechniq Glass coating recently tot to use it on my old junk glasses but after polish and clean it..i didn't use it...think its not worth to invest so expensive product on such old car
Posted 06 January 2012 - 10:17 AM
You already have it, why not use it? or getting new car?
