allan69
Posted 01 March 2012 - 09:28 AM
allan69
I have checked, there is no setting controlling the chat function. Did you login when you try to post in the Chat or can you try from another internet browser like Firefox?
Bro, finally it works with Firefox but why not IE? Is there any setting on IE to make it compatible?
My Rex is currently with Ecomap, customized Turbo Vacuum Hose, K&N Drop in Filter, Bendix 4WD Brake Pad (Front & Rear), Petronas Urania SUPREMO CI-4 Lubricant Oil, FUCH TiTAN ATF 3353, Rear Coil Dampener, Tufoil Engine Treatment, HID 4300K, . . . . .
neonlee
Posted 01 March 2012 - 10:05 AM
I'm the one who add the Chat function in the forum,the chat works in IE before , i'm still investigate how to make it work...
r3xt0n
Posted 01 March 2012 - 05:01 PM
Which version of IE are you on? IE earlier than Version 8 is known to have many compatibility problems and it is the most unsafest browser. If you are on older IE, better upgrade it if you intend to continue using. If not, just use Firefox for your browsing, it is much more user friendly, has tonnes of extensions and efficient too.
allan69
Posted 01 March 2012 - 09:08 PM
allan69
Bro, I am using IE Version 9.
r3xt0n
Posted 01 March 2012 - 10:08 PM
Try to Enable Compatability Mode on your IE 9 to see if it works. If not, IE 10 coming out soon.. hahaha
penapis
Posted 28 March 2012 - 12:00 AM
The e-mail/username information submitted could not be found.
i cant even reset password... How??
r3xt0n
Posted 28 March 2012 - 01:11 AM
Suspect could be the error caused during the data import process, will have to put a coder to check and fix these issues. Will arrange this once my guys are not so tight.
