Prius - Test Drive
Posted 23 September 2011 - 07:56 PM
Posted 24 September 2011 - 09:55 AM
yes..when u rev it hard..the engine generate rather loud noise and can be quite intrusive..but when it falls back to crusing speed..then everything is ok..agree with u the wind noise is there..but this is due to the motor is too quite and it make u hear "additional" noise..that make it a lil bit noisy..tats y it is not easy to built a lexus..everything is serene n quiet
Posted 26 September 2011 - 12:56 PM
i wonder if the lexus CT200H produce the same amount of 'noise'.....
Posted 26 September 2011 - 04:02 PM
On normal mode, it is not as noisy but on sport mode, yes. On EV mode, no sound at all!
CT200H uses the same engine & gearbox, just better insulation and build.
Posted 26 September 2011 - 10:58 PM
I have tested Prius and I currently own the latest Altis. They both are quite same in certain areas, i.e. sound noise from wind and tire. This is very true! The engine noise is not that obvious if you compare with tire/road noise and wind noise if you drive above 90km/h!! When you hit 110km/h then the wind noise becomes very very obvious!
If you cannot take these type of noises then either you go for Toyota Luxury Class(Camry) or Lexus !! You get what you paid.
Posted 27 September 2011 - 10:11 AM
Bro khlee23,
You have traded in your 308 for an Altis ? Cheers.
Posted 27 September 2011 - 11:31 AM
just wan to know the cvt in the prius hv how many gear?
The altis hv 7 speed,how come prius spec don't hv any.
Posted 27 September 2011 - 11:43 AM
Yes bro! You got it. I am currently driving a brand new Dual-VVTi / 7G Super-CVTi Altis.
Posted 27 September 2011 - 01:17 PM
Ouch...I guess the 308 gave you sleepless night
Posted 27 September 2011 - 01:50 PM
Bro,
Yours is 1.8G ? Thanks.
Bro,
I don't think so lah. Cheers.
