Another White Car Question!
Posted 13 September 2011 - 11:41 PM
Posted 14 September 2011 - 12:36 AM
having a white car sine new, i would say yes to all your questions. but through maintenance wash even APC at those trouble spots to flush the dirt out, polishing (AIO) and duragloss sealant, it has become less and less. until now, 8 months later, can leave the car unwashed for 2-3 weeks and streaks will not appear or appear less and can easily be washed away. this is with heavy downpour or light rain just enough to dirty the car, within the time it wasnt washed.
Posted 14 September 2011 - 09:28 AM
Mine is quite extreme. I just detailed my car last 2 weeks and the car is kept in an enclosed environment. Didn't really expose to rain till yesterday whereby there was a heavy downfall. Was at the club for 1 1/2 hour whereby the car was left in the open under the downfall. After that, can see dirt streaks on certain part of the body. Had to wash the car almost immediately. However, can see that the MG M16 Wax that I applied last 2 weeks is starting to deteriorate.
White oh white... why are you so hard to maintain???
Posted 14 September 2011 - 09:44 AM
But, that is not to worry (unless you're really anal about the look). What's more important is how easy (or difficult) they are to be washed off.
wax on white car, i have seen, tends to pick up and stick dirt easier and faster. more so for certain type of wax. M16 is one of them. i have 2 tubs of this m16.
now i use sealant exclusively for my white car...
but once in a while i put on wax. dont know why but syiok feeling when waxing a car and seeing a newly waxed car.
Posted 14 September 2011 - 10:02 AM
Yes I have that problem on my white cefiro. Mainly its on the front bonnet and its seems to be an oily substance which eats through sealants and waxes after you wash away the black streak with regular car wash the line no longer beads. Now testing with OC2.0. Seems promising. I just missed the rain yesterday, so got no chance to test. Where is the rain when you need it. hahahaha
Posted 14 September 2011 - 10:23 AM
I don't know why but I've tested the M16 vs DG 105 before, ie wax vs sealant. To me, M16 lasted longer than the DG105. Weird but that's my findings.
Perhaps, I need to repeat the research
Posted 14 September 2011 - 10:35 AM
Posted 14 September 2011 - 11:10 AM
as krismas says, it is not a pure wax. it is a hybrid wax/sealant. which thru the same account what i think Dodo Juice Hybrid Wax is. but that's another matter altogether.
the main reason why i stop using it for my white car is the enhanced ability to pick up dirt and streaks especially after rain.
Posted 14 September 2011 - 12:18 PM
I find that DG105 is not the best beader but its stain resistance is quite good. I notice if you just use DG105 and don't top it off with QD, DG Aquawax or anything else, the stain resistance is the best. It is the "topper" which gets stained when then affects the DG105 below.
So for my White cefiro I just use straight DG105 and wash the car. After every wash I don't QD or anything else as what ever you put on top will get stained easily.
So I just recommend DG105 straight and car wash. When the beading starts to wear away just add more DG105. Simple.
Keeping my fingers crossed with OC2.0, so far fresh stains are easily washed away, same with bugs which is consistent with what many people has reported on the net. Best thing is no need to QD or maintain after wash.
