Don't worried, your problem is as same as mine last time.
1st to check your Vacuum hose leaking,
2nd try to swap your modulators or use the contact cleaner to clean it and blow with compressed air,
3rd clean your Intake monifold and EGR as well..
After i done a few cleaning process, No Taxi can over take me during up hill to Genting.
Another way is Eco Map, this will help you alot....
cheers ! haha ...
my car D2-D4 very power, but D1 no power. so , when i drive my car to genting uphill, i walking also faster than my car ler if i maintain 1st gear ... zzz .... should i change both modulator ?? how do u think ??
anyway , how will u define not enuf turbo charge ?? issit mean the turbo not enuf power ??? press pedal take very long time to speed ??
where u going to do it ?? DIY ?? maybe i free then i can go see see ^^ hahahaha
hi bro..
I have tested by cleaning...eeerrrr really basuh the engine with water spray and soap.. the symptom after that same as you describe..D1 no power/response, press pedal until angkat punggong than count 1,2,3,4,5,6 the rpm slowly goes up then the power come in D2 to D4.
I then clean the sensor contact one by one.and give a test drive after each cleaning.THE CULPRIT IS THE MAP SENSOR LOCATED ON TOP OF MANIFOLD. after clean the MAP with contact cleaner, the power back to normal. if the connection not good or the MAP fail, it can't detect the boost or give wrong reading to ECU, so less diesel and wrong timing injected..
NIK
