Yes, Rubber Damper is available. Replied to your PM.
Aug Group Order
Posted 19 August 2011 - 12:06 PM
Posted 19 August 2011 - 08:03 PM
Posted 19 August 2011 - 08:42 PM
Posted 19 August 2011 - 09:13 PM
Your order already been arranged and will be collected tomorrow.
Posted 13 September 2011 - 12:17 PM
Order Collection - 20 Aug 2011
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $450
ii. Malee Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt - RM70
18. Aircon Cabin Filter (Korea OEM) - RM50
Order List
1. Greydevil - $130
i. Transmission Mounting - $130
2. Uchirex - RM1,450 - Paid RM1,450
2. ATF Oil Package
3. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rubber Damper - RM80
6. Contitech Fan Belt - RM70
3. Neonlee - RM70
- Contitech Fan belt - 1 X $70 = RM70
4. zull1101 - RM440
i. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
ii. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
iii. Rubber Damper (2pcs front & 2pcs rear) - $80/set
5.
6.
7.
8.
9.
10.
Total Order = $2,090
Payment Paid = RM1,890
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
Hello bro,
Since i am from kota kinabalu, sabah, how does the things come to me if i wish to join in the group order? Does the trasportation fees expensive?
Posted 13 September 2011 - 02:57 PM
Depending on the items weight, Post Laju should be the cheapest option. I believe the cost saving definitely more than the courier fees because your workshop will still have to bear the same courier cost.
Posted 13 September 2011 - 05:04 PM
Ok, by the way who will send the items? Have you or anyone send it to KK before?
Posted 13 September 2011 - 08:13 PM
One of our Committee Team will send via Post Laju, cost depending on weight of the package. Nope, we do not normally need to courier orders. This is just as a friendly help to fellow bros.
Posted 13 September 2011 - 09:50 PM
ok thanks a lot for the help.
